Ga door naar hoofdinhoud
Acer Aspire S3 MS2346 Display Assembly Replacement
Wat je nodig hebt
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: stap 2, afbeelding 1 van 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: stap 2, afbeelding 2 van 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: stap 2, afbeelding 3 van 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: stap 3, afbeelding 1 van 2 Acer Aspire S3 MS2346 Display Assembly Replacement: stap 3, afbeelding 2 van 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 1 van 2 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 2 van 2
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: stap 6, afbeelding 1 van 1
    • Unlatch the screen from the frame
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nikolas I Steckley
666 Reputatie
5 handleidingen geschreven
3 opmerkingen
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - Antwoord
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 30
Altijd: 3,120
