Ga door naar hoofdinhoud
Acer Aspire R7-371T-72CF Wifi Chip Replacement
Wat je nodig hebt
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: stap 1, afbeelding 1 van 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: stap 1, afbeelding 2 van 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 2, afbeelding 1 van 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 3, afbeelding 1 van 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 3, afbeelding 2 van 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 3, afbeelding 3 van 3
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 4, afbeelding 1 van 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 4, afbeelding 2 van 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 4, afbeelding 3 van 3
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 5, afbeelding 1 van 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 5, afbeelding 2 van 2
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: stap 6, afbeelding 1 van 1
    • Remove the chip by pulling towards the edge of the computer.
Conclusie
Dylan Meintser
476 Reputatie
4 handleidingen geschreven
Cal Poly, Team S8-G5, Banghart Fall 2017 Lid van Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Leden
5 handleidingen geschreven
Één opmerking
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 543
