Ga door naar hoofdinhoud
Acer Aspire R7-371T-72CF Power Port Replacement
Wat je nodig hebt
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: stap 1, afbeelding 1 van 2 Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: stap 1, afbeelding 2 van 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: stap 2, afbeelding 1 van 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: stap 3, afbeelding 1 van 3 Acer Aspire R7-371T-72CF Power Port Replacement: stap 3, afbeelding 2 van 3 Acer Aspire R7-371T-72CF Power Port Replacement: stap 3, afbeelding 3 van 3
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: stap 4, afbeelding 1 van 3 Acer Aspire R7-371T-72CF Power Port Replacement: stap 4, afbeelding 2 van 3 Acer Aspire R7-371T-72CF Power Port Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: stap 5, afbeelding 1 van 1
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ethan Frey
117 Reputatie
1 Handleiding geschreven
Cal Poly, Team S8-G5, Banghart Fall 2017 Lid van Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Leden
5 handleidingen geschreven
4 opmerkingen
What’s the part number for the power jack cable, and who sells it?
AcerFan - Antwoord
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
Jorge Prado - Antwoord
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - Antwoord
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 1,693
