Ga door naar hoofdinhoud
Acer Aspire R7 Speakers Replacement
Wat je nodig hebt
  1. Acer Aspire R7 Speakers Replacement, Cover: stap 1, afbeelding 1 van 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Speakers Replacement: stap 2, afbeelding 1 van 3 Acer Aspire R7 Speakers Replacement: stap 2, afbeelding 2 van 3 Acer Aspire R7 Speakers Replacement: stap 2, afbeelding 3 van 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Speakers Replacement, Speakers: stap 4, afbeelding 1 van 2 Acer Aspire R7 Speakers Replacement, Speakers: stap 4, afbeelding 2 van 2
    • Locate the clip attaching the right-side speakers to the motherboard.
    • Carefully pull on the clip until it detaches from the motherboard.
    • Use a plastic opening tool if needed.
  5. Acer Aspire R7 Speakers Replacement: stap 5, afbeelding 1 van 2 Acer Aspire R7 Speakers Replacement: stap 5, afbeelding 2 van 2
    • Remove the two 3.5mm #00 Phillips screws which hold the speaker in place.
    • Carefully lift the right-side speaker assembly away from the motherboard.
  6. Acer Aspire R7 Speakers Replacement: stap 6, afbeelding 1 van 2 Acer Aspire R7 Speakers Replacement: stap 6, afbeelding 2 van 2
    • Locate the clip attaching the left-side speakers to the motherboard.
  7. Acer Aspire R7 Speakers Replacement: stap 7, afbeelding 1 van 2 Acer Aspire R7 Speakers Replacement: stap 7, afbeelding 2 van 2
    • Carefully lift the left-side speaker assembly away from the motherboard.
Conclusie
Andrew Rodiek
601 Reputatie
4 handleidingen geschreven
USF Tampa, Team 3-4, Hickman Winter 2015 Lid van USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 679
