Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove all 10 of the lower case screws with a T9 torx screwdriver.
Remove the long middle rubber piece with a plastic spludger or small flat head screwdriver.
Remove the 2 torx screws.
Remove the small middle rubber piece with a plastic spludger or small flat head screwdriver.
Unscrew the torx screw. It is the same size as the bottom front row screws.
Disconnect the battery connector from the motherboard.
Remove the hard drive by slightly lifting it up on the left side and slightly pulling it to the left carefully untill it pops out.
Unscrew the screw holding down the WiFi card.
Remove the WiFi card.
Disconnect the two keyboard ribbon cables
Disconnect the left speaker wire.
Disconnect the front lights ribbon cable.
Disconnect the I/O board ribbon cable.
Disconnect the heat sink fan wire.
Disconnect the microphone wire.
Remove the 3 heat sink screws.
Lift up the heat sink from the motherboard and remove it.
Remove the 2 heat sink fan screws.
Remove the heat sink fan.
Remove the power button ribbon cable from the motherboard.
Remove the 4 silver hinge screws.
Remove the 2 black hinge screws.
Carefully open the laptop and the hinges will pop off the frame.
Remove the 4 T9 torx screws from the display assembly where the model number and serial numbers stickers are located and swap that panel to the replacement display assembly. Completing this step allows for your computer to retain its original identification information.
9 andere personen hebben deze handleiding voltooid.
5 opmerkingen
I ordered the display on eBay.
This is just a teardown. Nobody sells the entire display assembly with shell, and the steps to go over replacing the actual display panel are completely absent.
Although correct this doesn't help and should probably be taken down. As mentioned by others you can't buy the entire screen section, you can only buy the LCD part. Replacing the LCD requires removing the glass and having to glue it back on which is probably beyond most people's capability. This article is therefore misleading.
