Ga door naar hoofdinhoud
Acer Aspire R7 Battery Replacement
Wat je nodig hebt
  1. Acer Aspire R7 Battery Replacement, Cover: stap 1, afbeelding 1 van 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: stap 2, afbeelding 1 van 3 Acer Aspire R7 Battery Replacement: stap 2, afbeelding 2 van 3 Acer Aspire R7 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Acer Aspire R7 Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: stap 5, afbeelding 1 van 3 Acer Aspire R7 Battery Replacement: stap 5, afbeelding 2 van 3 Acer Aspire R7 Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
Conclusie
12 andere personen hebben deze handleiding voltooid.
F Fernandez
435 Reputatie
2 handleidingen geschreven
USF Tampa, Team 3-4, Hickman Winter 2015 Lid van USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Leden
7 handleidingen geschreven
6 opmerkingen
great instructions
amaryheart7777777 - Antwoord
What is the battery reference for replacement ?
skalpinou - Antwoord
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Antwoord
hey how do you want då sel it for
Alex santos - Antwoord
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 37
Altijd: 41,159
