Ga door naar hoofdinhoud
Acer Aspire R5-571T-59DC Motherboard Replacement
Wat je nodig hebt
  1. Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: stap 1, afbeelding 1 van 2 Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: stap 1, afbeelding 2 van 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: stap 2, afbeelding 1 van 3 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: stap 2, afbeelding 2 van 3 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: stap 2, afbeelding 3 van 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC  Motherboard Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC  Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the hard drive up and out of the laptop.
  5. Acer Aspire R5-571T-59DC  Motherboard Replacement, Fan: stap 5, afbeelding 1 van 1
    • Remove the seven 0.7mm Phillips #00 screws securing the fan in place.
  6. Acer Aspire R5-571T-59DC  Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Unplug fan from motherboard.
    • Lift and remove fan from case.
  7. Acer Aspire R5-571T-59DC  Motherboard Replacement, RAM: stap 7, afbeelding 1 van 1
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  8. Acer Aspire R5-571T-59DC  Motherboard Replacement: stap 8, afbeelding 1 van 3 Acer Aspire R5-571T-59DC  Motherboard Replacement: stap 8, afbeelding 2 van 3 Acer Aspire R5-571T-59DC  Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
  9. Acer Aspire R5-571T-59DC  Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Remove the nine 0.7mm Phillips #00 screws from the motherboard.
  10. Acer Aspire R5-571T-59DC  Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Use a spudger to flip up the retaining flaps on all of the ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
    • Lift up and remove the motherboard.
Conclusie
Kelly Johnston
600 Reputatie
4 handleidingen geschreven
USF Tampa, Team S20-G2, Passmore Spring 2018 Lid van USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Leden
7 handleidingen geschreven
Één opmerking
Hi, my laptop is Acer R5-571TG-765T.
1. Does the bare bones motherboard have the same physical configuration as your R5-571T-59DC?
2. Is M.2 NVMe SSD compatible with my motherboard?
3. My laptop runs hot even with a cooling fan stand beneath. Would you recommend NVMe?
4. If heat is a problem, and availability of reputable and affordable M.2 SATA is lacking where I am -- will I be able to use a 2.5" SATA SSD as a boot drive and keep my existing 2.5" SATA HDD as a D drive at the same time?
Thank you!
availability - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,908
