Inleiding
The RAM (or memory) in your Acer Aspire R5-571T-57Z0 is what is used to temporarily store data while the laptop is running. It will hold application data as well as file data as your computer reads and writes to various files.
If you are receiving frequently memory warnings or having difficulty running software, there may be an issue with your RAM. Before continuing with this guide and replacing your RAM, verify that you do not have excessive software running on your computer. This can cause memory to fill up and will drastically decrease the speed of your computer. Consult our troubleshooting guide for more information.
This guide will show you how to replace the RAM in your Acer Aspire R5-571T-57Z0. Before starting this guide, make sure to power off your computer and disconnect it from any external devices. Once these steps are taken, replacing your RAM will be a simple process.
Wat je nodig hebt
Remove twelve 4.0 mm screws from the back of the laptop using a Phillips #00 screwdriver.
Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
Unplug the cable connected to the RAM.
Carefully remove the battery.
Één andere persoon heeft deze handleiding voltooid.
