Inleiding
The battery in your Acer Aspire R5-571T-57Z0 is what is used to power the laptop, enabling it to run without the use of a charger. The battery must remain charged in order for the laptop to run and must be recharged periodically in order to function.
If your laptop is running out of power very quickly, failing to charge, charging slowly, or not powering on at all, your battery may be damaged and require replacement. Before continuing with this guide and replacing your battery, make sure that your charger is working properly. It is possible that you are dealing with a broken charger rather than a broken battery. Consult our troubleshooting guide for more information.
This guide will show you how to replace the battery in your Acer Aspire R5-571T-57Z0. Before starting this guide, make sure to power off your computer and disconnect it from any external devices. Once these steps are taken, replacing your battery will be a simple process.
Wat je nodig hebt
Remove twelve 4.0 mm screws from the back of the laptop using a Phillips #00 screwdriver.
Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
Unplug the cable connected to the RAM.
Carefully remove the battery.
