Ga door naar hoofdinhoud
Acer Aspire R5-471T-52EE Fan Replacement
Wat je nodig hebt
  1. Acer Aspire R5-471T-52EE Fan Replacement, Back Cover: stap 1, afbeelding 1 van 2 Acer Aspire R5-471T-52EE Fan Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Fan Replacement: stap 2, afbeelding 1 van 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Fan Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Remove seven 3 mm screws using the Phillips #00 screwdriver.
  4. Acer Aspire R5-471T-52EE Fan Replacement: stap 4, afbeelding 1 van 1
    • Once the screws are removed, disconnect seven plugs from the motherboard.
    • Keep in mind that a majority of these wires are extremely thin and fragile. Disconnect them with light force and care.
  5. Acer Aspire R5-471T-52EE Fan Replacement: stap 5, afbeelding 1 van 1
    • Flip up the small black portion the connectors are connected to and disconnect them from the motherboard.
    • Grab the yellow piece of tape to easily remove the connection from the motherboard with nothing more than some gentle force.
    • Remove the large black ribbon wire by gently pulling on the white tab towards yourself.
    • Remove the large white ribbon wire by pulling up on the small black tab.
  6. Acer Aspire R5-471T-52EE Fan Replacement: stap 6, afbeelding 1 van 1
    • Remove the four remaining screws located on the fan using the Phillips #00 screwdriver.
  7. Acer Aspire R5-471T-52EE Fan Replacement, Fan: stap 7, afbeelding 1 van 2 Acer Aspire R5-471T-52EE Fan Replacement, Fan: stap 7, afbeelding 2 van 2
    • Flip the motherboard over so that the silver and copper covers are exposed.
    • Use the opening tool to gently lift the copper cover off the board by sliding the tool underneath the edge.
  8. Acer Aspire R5-471T-52EE Fan Replacement: stap 8, afbeelding 1 van 1
    • Unplug the two power cables for the fans from the motherboard.
    • Remove the four mounting screws from the motherboard using a Phillips #00 screwdriver.
  9. Acer Aspire R5-471T-52EE Fan Replacement: stap 9, afbeelding 1 van 1
    • Gently remove the fans from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 305
