Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Acer Aspire One ZG5 Wireless Card Replacement
Wat je nodig hebt
  1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Wireless Card Replacement: stap 8, afbeelding 1 van 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Doug Gallatin
6.337 Reputatie
10 handleidingen geschreven
Cal Poly, Team 7-49, Amido Fall 2010 Lid van Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Leden
27 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 24
Altijd: 23,539
