Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Acer Aspire One ZG5 Top Case Replacement
Wat je nodig hebt
  1. Acer Aspire One ZG5 Top Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Top Case Replacement: stap 2, afbeelding 1 van 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Top Case Replacement: stap 3, afbeelding 1 van 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Top Case Replacement, Wireless Card: stap 4, afbeelding 1 van 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Top Case Replacement: stap 5, afbeelding 1 van 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Top Case Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Top Case Replacement: stap 7, afbeelding 1 van 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Top Case Replacement: stap 8, afbeelding 1 van 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Acer Aspire One ZG5 Top Case Replacement, Keyboard: stap 9, afbeelding 1 van 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Top Case Replacement: stap 10, afbeelding 1 van 3 Acer Aspire One ZG5 Top Case Replacement: stap 10, afbeelding 2 van 3 Acer Aspire One ZG5 Top Case Replacement: stap 10, afbeelding 3 van 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Top Case Replacement: stap 11, afbeelding 1 van 2 Acer Aspire One ZG5 Top Case Replacement: stap 11, afbeelding 2 van 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Top Case Replacement: stap 12, afbeelding 1 van 2 Acer Aspire One ZG5 Top Case Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  13. Acer Aspire One ZG5 Top Case Replacement, Top Case: stap 13, afbeelding 1 van 1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Top Case Replacement: stap 14, afbeelding 1 van 2 Acer Aspire One ZG5 Top Case Replacement: stap 14, afbeelding 2 van 2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Top Case Replacement: stap 15, afbeelding 1 van 1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Top Case Replacement: stap 16, afbeelding 1 van 3 Acer Aspire One ZG5 Top Case Replacement: stap 16, afbeelding 2 van 3 Acer Aspire One ZG5 Top Case Replacement: stap 16, afbeelding 3 van 3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Top Case Replacement: stap 17, afbeelding 1 van 2 Acer Aspire One ZG5 Top Case Replacement: stap 17, afbeelding 2 van 2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Top Case Replacement: stap 18, afbeelding 1 van 2 Acer Aspire One ZG5 Top Case Replacement: stap 18, afbeelding 2 van 2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Doug Gallatin
6.337 Reputatie
10 handleidingen geschreven
Cal Poly, Team 7-49, Amido Fall 2010 Lid van Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 15,753
