Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
You will remove several cables, screws, and finally the motherboard. This opens up the device in order to repair practically everything.
  1. Turn the netbook upside down with the battery at the top, away from you.
    • Turn the netbook upside down with the battery at the top, away from you.
  2. Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Slide the latch located on the opposite hinge from the lock while pushing the battery up.
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Lift up the panel and remove it from the case.
    • Lift up the panel and remove it from the case.
  6. Disconnect the two antenna cables from the left side of the wireless card.
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Gently lift up the left side of the wireless card and slide the card out of its socket.
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Turn the netbook over and open the display so that the keyboard is facing you.
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  11. There are three tabs located on the top of the keyboard. Start with the spudger pointing towards the display and pry up to push each tab off the keyboard. As you move to the next tab, ensure the previous tab doesn't reset itself.
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  12. Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side. There is a short ribbon cable connecting the keyboard to the netbook.
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  13. Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable. Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  14. Close the display and turn the ZG5 over so that the battery compartment faces away from you.
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  15. Remove three 5.8 mm Phillips #0 screws from the bottom of the case Remove three 3.9 mm  Phillips #1 screws  from the battery compartment.
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  16. Turn the netbook back over and open the display with the keyboard cavity facing you.
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  17. Flip up the retaining flap on the trackpad ribbon cable ZIF connector. Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard. Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  18. Remove the five black 4.7 mm Phillips #0 screws from the metal casing. Remove the single silver 4.3 mm Phillips #00 screw from the right side of  the metal casing.
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  19. Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case. Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  20. Disconnect the two antenna cables from the right side of the wireless card.
    • Disconnect the two antenna cables from the right side of the wireless card.
  21. Remove the single 3.9 mm Phillips #1 screw from the wireless card.
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  22. Gently pull the wireless card to the right and slide it out of its socket.
    • Gently pull the wireless card to the right and slide it out of its socket.
  23. Disconnect the display cable from the top left of the motherboard.
    • Disconnect the display cable from the top left of the motherboard.
  24. Disconnect the speaker cable from its socket on the motherboard. Disconnect the speaker cable from its socket on the motherboard.
    • Disconnect the speaker cable from its socket on the motherboard.
  25. Remove three 3.9 mm Phillips #1  screws from the small  I/O board.
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
  26. Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  27. Gently lift the I/O board up from the right side of the case.
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
  28. Lift the entire motherboard assembly out the case.
    • Lift the entire motherboard assembly out the case.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Doug Gallatin
6.121 Reputatie
10 handleidingen geschreven
Cal Poly, Team 7-49, Amido Fall 2010 Lid van Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Leden
20 handleidingen geschreven
Hi Doug,
I'm about to rebuild my old acer netbook ZG5 and discovered that there is nothing under the wireless card door. Does this mean that the wireless card is embedded? I ask because I am now doubting that the netbook was ever wifi (but it must have been.) Newegg doesn't seem to have any motherboards available for the ZG5 so I'm thinking I'll get one from ebay. Thanks for the guide.
Matt
mattearls - Antwoord
Bro, i got problem with this mobo...
The resistor is broke, its located on side of keyboard port...
I'm trying to de-solder but it wont move.
What should i do?
Peter Dorothy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 45
Altijd: 56,650
