Ga door naar hoofdinhoud
Acer Aspire One ZG5 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: stap 5, afbeelding 1 van 3 Acer Aspire One ZG5 Keyboard Replacement: stap 5, afbeelding 2 van 3 Acer Aspire One ZG5 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: stap 6, afbeelding 1 van 2 Acer Aspire One ZG5 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: stap 7, afbeelding 1 van 2 Acer Aspire One ZG5 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Doug Gallatin
6.337 Reputatie
10 handleidingen geschreven
Cal Poly, Team 7-49, Amido Fall 2010 Lid van Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Leden
27 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 18
Altijd: 24,617
