Ga door naar hoofdinhoud
Acer Aspire One D255E RAM Replacement
Wat je nodig hebt
  1. Acer Aspire One D255E RAM Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E RAM Replacement: stap 2, afbeelding 1 van 2 Acer Aspire One D255E RAM Replacement: stap 2, afbeelding 2 van 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E RAM Replacement: stap 3, afbeelding 1 van 3 Acer Aspire One D255E RAM Replacement: stap 3, afbeelding 2 van 3 Acer Aspire One D255E RAM Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E RAM Replacement: stap 4, afbeelding 1 van 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E RAM Replacement, Back Panel: stap 5, afbeelding 1 van 2 Acer Aspire One D255E RAM Replacement, Back Panel: stap 5, afbeelding 2 van 2
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E RAM Replacement: stap 6, afbeelding 1 van 2 Acer Aspire One D255E RAM Replacement: stap 6, afbeelding 2 van 2
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E RAM Replacement: stap 7, afbeelding 1 van 3 Acer Aspire One D255E RAM Replacement: stap 7, afbeelding 2 van 3 Acer Aspire One D255E RAM Replacement: stap 7, afbeelding 3 van 3
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E RAM Replacement, RAM: stap 8, afbeelding 1 van 3 Acer Aspire One D255E RAM Replacement, RAM: stap 8, afbeelding 2 van 3 Acer Aspire One D255E RAM Replacement, RAM: stap 8, afbeelding 3 van 3
    • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
    • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
Conclusie
7 andere personen hebben deze handleiding voltooid.
Brian
1.302 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 4,722
