Ga door naar hoofdinhoud
Acer Aspire One D255E Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Keyboard Replacement: stap 2, afbeelding 1 van 2 Acer Aspire One D255E Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Keyboard Replacement: stap 3, afbeelding 1 van 3 Acer Aspire One D255E Keyboard Replacement: stap 3, afbeelding 2 van 3 Acer Aspire One D255E Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brian
1.248 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 28
Altijd: 2,366
