Ga door naar hoofdinhoud
Acer Aspire One D250-1151 Keyboard Key Replacement
Wat je nodig hebt
  1. Acer Aspire One D250-1151 Keyboard Key Replacement, Keyboard Key: stap 1, afbeelding 1 van 1
    • Open the Computer so you have access to the keyboard and the screen.
  2. Acer Aspire One D250-1151 Keyboard Key Replacement: stap 2, afbeelding 1 van 1
    • Do not apply too much force while removing the key or the edge under the key will be pushed down, preventing replacement.
    • Use the plastic opening tool to lift the key from the right side until it comes off.
    • You will hear a pop, this is normal. In some cases the inner plastic part of the key will also come off.
  3. Acer Aspire One D250-1151 Keyboard Key Replacement: stap 3, afbeelding 1 van 3 Acer Aspire One D250-1151 Keyboard Key Replacement: stap 3, afbeelding 2 van 3 Acer Aspire One D250-1151 Keyboard Key Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to remove the plastic brackets from the keyboard.
    • Picture two and three show the correct orientation of the plastic pieces and how they are connected.
  4. Acer Aspire One D250-1151 Keyboard Key Replacement: stap 4, afbeelding 1 van 1
    • Remove the round piece by taking the axils of the circular piece out of the holes located in the center of the square piece.
    • Make sure the circular piece correctly fits into the rectangular piece while laying flat. If it does not do this the circular piece is facing the wrong way and will need to be removed, turned around, and reconnected.
Conclusie
This process should work for any of the keys in the keyboard
Donny McKay
526 Reputatie
4 handleidingen geschreven
Baylor, Team 5-11, Williams Fall 2016 Lid van Baylor, Team 5-11, Williams Fall 2016
BU-WILLIAMS-F16S5G11
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 62
Altijd: 5,300
