Ga door naar hoofdinhoud
Acer Aspire One D250-1151 Hard drive Replacement
Wat je nodig hebt
  1. Acer Aspire One D250-1151 Hard drive Replacement, Hard drive: stap 1, afbeelding 1 van 1
    • Place the computer face down on a flat surface.
  2. Acer Aspire One D250-1151 Hard drive Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the Largest panel using a Philips PH1 screwdriver in a counterclockwise motion.
  3. Acer Aspire One D250-1151 Hard drive Replacement: stap 3, afbeelding 1 van 1
    • Lift the panel with your finger to reveal the hard drive.
    After Step 3, you must remove the single black screw to release the aluminum drive tray, then proceed with Step 4.
    bmcd - Antwoord
  4. Acer Aspire One D250-1151 Hard drive Replacement: stap 4, afbeelding 1 van 1
    • Slide the hard drive towards the battery until it is no longer connected.
  5. Acer Aspire One D250-1151 Hard drive Replacement: stap 5, afbeelding 1 van 1
    • Lift the hard drive out of the compartment.
    After you remove the drive from the compartment, you must remove the four (4) screws on the side of the aluminum drive tray to remove the drive.
    bmcd - Antwoord
Conclusie
Donny McKay
526 Reputatie
4 handleidingen geschreven
Baylor, Team 5-11, Williams Fall 2016 Lid van Baylor, Team 5-11, Williams Fall 2016
BU-WILLIAMS-F16S5G11
3 Leden
15 handleidingen geschreven
1Gids Commentaar
Easier than trying to reformat it on WindowsXP
waltcs1 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 1,445
