Ga door naar hoofdinhoud
Acer Aspire One D225-1625 Wireless Card Replacement
Wat je nodig hebt
  1. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D225-1625 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: stap 3, afbeelding 1 van 2 Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: stap 3, afbeelding 2 van 2
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel and slide back and forth across the edge until the back gently pops off.
  4. Acer Aspire One D225-1625 Wireless Card Replacement: stap 4, afbeelding 1 van 2 Acer Aspire One D225-1625 Wireless Card Replacement: stap 4, afbeelding 2 van 2
    • Use tweezers to disconnect the black and white wires from the wireless card by pulling them up off the card.
  5. Acer Aspire One D225-1625 Wireless Card Replacement: stap 5, afbeelding 1 van 2 Acer Aspire One D225-1625 Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to unscrew the top right screw on the wireless card.
    • Pull out wireless card by sliding it out to your right.
Conclusie
Één opmerking
Awesome I changed wireless card with your instruction this is a helpful 👍👍
sohil shekh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 28
Altijd: 416
