Inleiding
In this guide, you will remove the USB Port from the device by removing two screws and disconnecting the ribbon cable connecting it to the motherboard.
Wat je nodig hebt
Remove eleven 4 mm Phillips #1 screws
Pull the backplate off using your fingers.
Één andere persoon heeft deze handleiding voltooid.
