Inleiding
Low quality or old thermal compound can lead the CPU to overheat, which slows down performance and also shortens the life of the device. Follow this guide for detailed instructions on how to access and replace the thermal compound.
Wat je nodig hebt
Power the laptop off.
Flip the laptop over and position it so the opening faces you.
Remove the rubber foot located near the opening side of the device using tweezers.
Position the computer so the opening side faces you.
Remove the four 2.5-mm screws using a PH0 screwdriver.
Follow the guide below for the replacement of the thermal paste.
