Ga door naar hoofdinhoud
Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement
Wat je nodig hebt
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement, Back Panel: stap 1, afbeelding 1 van 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement, Back Panel: stap 1, afbeelding 2 van 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement, Back Panel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 2, afbeelding 1 van 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 3, afbeelding 1 van 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 3, afbeelding 2 van 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 3, afbeelding 3 van 3
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 4, afbeelding 1 van 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 4, afbeelding 2 van 2
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 5, afbeelding 1 van 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 5, afbeelding 2 van 2
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
  6. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement, Thermal Paste: stap 6, afbeelding 1 van 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement, Thermal Paste: stap 6, afbeelding 2 van 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement, Thermal Paste: stap 6, afbeelding 3 van 3
    • Position the computer so the opening side faces you.
    • Remove the four 2.5-mm screws using a PH0 screwdriver.
    • Follow the numerical order labeled on the metallic plate.
  7. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 7, afbeelding 1 van 1
    • Remove the metallic plate.
    • This metallic plate is referred to as a heat sink. The job of the heat sink is to help move heat away from the CPU.
  8. Acer Aspire One Cloudbook 11 AO1-131-C7DW Thermal Paste Replacement: stap 8, afbeelding 1 van 1
Conclusie
Luz Villegas
452 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team S1-G4, Bruce Fall 2017 Lid van CSU Fullerton, Team S1-G4, Bruce Fall 2017
CSUF-BRUCE-F17S1G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 512
