Ga door naar hoofdinhoud
Acer Aspire One 722 Hard Drive Replacement
Wat je nodig hebt
  1. Acer Aspire One 722 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Hard Drive Replacement: stap 4, afbeelding 1 van 2 Acer Aspire One 722 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Ensure the Laptop is powered down with the battery removed prior to beginning.
    • With the battery cavity facing away from you, use the Phillips #0 to remove the center screw which secures the backplate.
    • Make sure to keep track of these screws for reassembly.
  7. Acer Aspire One 722 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Gently lift up and pull away the backplate from the chassis to remove.
  8. Acer Aspire One 722 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • With the backplate removed, locate the HDD in the upper left corner of the device.
    • Use the Phillips #0 screwdriver to remove the four corner screws securing the HDD to the chassis.
  9. Acer Aspire One 722 Hard Drive Replacement: stap 9, afbeelding 1 van 2 Acer Aspire One 722 Hard Drive Replacement: stap 9, afbeelding 2 van 2
    • Gently lift and secure the HDD with one hand and carefully remove the SATA and power connections with your other hand.
    • Once removed, store the replaced drive in an anti-static environment to ensure its integrity.
  10. Acer Aspire One 722 Hard Drive Replacement: stap 10, afbeelding 1 van 3 Acer Aspire One 722 Hard Drive Replacement: stap 10, afbeelding 2 van 3 Acer Aspire One 722 Hard Drive Replacement: stap 10, afbeelding 3 van 3
    • With your replacement HDD in hand, reseat the power and SATA cables removed from the previous drive.
    • The plugs are diffrent sizes so there is no fear of mixing them up
    • With the cables attached, align the four mounting points in the corner of the drive with the chassis and reseat the four Phillips #0 screws that were removed earlier.
Conclusie
To reassemble your device, follow these instructions in reverse order., taking special care in replacing the back cover. and battery.
4 andere personen hebben deze handleiding voltooid.
Christian Barboza
818 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Leden
10 handleidingen geschreven
Één opmerking
لا يعمل بعد انسطاب عليه ماء ما الحل
Belql Sayes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 5,473
