Ga door naar hoofdinhoud
Acer Aspire One 532h-2806 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire One 532h-2806 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Make sure the laptop is turned off and the battery is removed.
    • Above the top row of the keys, locate three plastic latches.
  2. Acer Aspire One 532h-2806 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Use the medal spudger to press each tab. The keyboard should release.
    • Slide the spudger, so that the tabs do not reset after pressing each one.
  3. Acer Aspire One 532h-2806 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the keyboard up.
    • The keyboard ribbon cable is still attached to the motherboard.
  4. Acer Aspire One 532h-2806 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Carefully unplug the connector sticker on the back of the keyboard.
    • Be gentle, do not force it out.
  5. Acer Aspire One 532h-2806 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the keyboard.
Conclusie
Julie Paula
527 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 380
