Inleiding
This guide will show how to remove the small back plate on your netbook. The removal of the plate is necessary to access your netbook’s RAM.
Wat je nodig hebt
Use the #0 Phillips Screw bit with the Screwdriver to remove the single 6mm Phillips screw from the small back plate.
Één andere persoon heeft deze handleiding voltooid.
