Inleiding
This guide will show how to remove the HDD from your netbook. The removal of the hard drive will allow you to replace it or upgrade it to a Solid State Drive (SSD).
Wat je nodig hebt
Use a #0 Phillips screwdriver to remove the three 6mm screws from the larger back plate.
Locate the HDD after the back plate is removed. It will be the large rectangle that takes up most of the space.
4 andere personen hebben deze handleiding voltooid.
