Ga door naar hoofdinhoud
Acer Aspire M5-583P-6423 Battery Jack Replacement
Wat je nodig hebt
  1. Acer Aspire M5-583P-6423 Battery Jack Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Aspire M5-583P-6423 Battery Jack Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Aspire M5-583P-6423 Battery Jack Replacement, Battery: stap 1, afbeelding 3 van 3
    • Turn the computer off and close it. Disconnect the charging cable from the laptop and place the laptop upside down.
    • Remove seventeen M2.5x8mm screws on the back cover of the laptop with the Phillips #00 screwdriver.
  2. Acer Aspire M5-583P-6423 Battery Jack Replacement: stap 2, afbeelding 1 van 2 Acer Aspire M5-583P-6423 Battery Jack Replacement: stap 2, afbeelding 2 van 2
    • Push the back cover up from each side using the iFixit opening tool.
    • You’ll hear a popping sound as you lift the back cover.
    • Once the back cover is separated, you’ll see all the internal components of the laptop.
  3. Acer Aspire M5-583P-6423 Battery Jack Replacement: stap 3, afbeelding 1 van 2 Acer Aspire M5-583P-6423 Battery Jack Replacement: stap 3, afbeelding 2 van 2
    • Pull the rainbow cord out by using the iFixit opening tool on each side of its connecting slot.
    • This step can be done by using your fingers, but its highly recommended to use the iFixit removal tool instead.
  4. Acer Aspire M5-583P-6423 Battery Jack Replacement: stap 4, afbeelding 1 van 1
    • Remove the M2.5 x 3mm screw that holds down the battery using the Phillips #00 screwdriver.
  5. Acer Aspire M5-583P-6423 Battery Jack Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery up from its edges and pull back slightly towards the hinges to remove the battery.
    • The battery is now detached from the laptop and can be set aside.
  6. Acer Aspire M5-583P-6423 Battery Jack Replacement, Battery Jack: stap 6, afbeelding 1 van 3 Acer Aspire M5-583P-6423 Battery Jack Replacement, Battery Jack: stap 6, afbeelding 2 van 3 Acer Aspire M5-583P-6423 Battery Jack Replacement, Battery Jack: stap 6, afbeelding 3 van 3
    • Your laptop's battery jack is located in the red boxed area. The red arrow shows where your power cable connects.
    • Disconnect the battery jack by gently pushing away the white slot in the arrows direction.
    • Gently grab the battery jack cable and remove it from the laptop’s motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 267
