Ga door naar hoofdinhoud
Acer Aspire ES1-711-P1UV Screen Replacement
Wat je nodig hebt
  1. Acer Aspire ES1-711-P1UV Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Screen Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Screen Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Screen Replacement, Screen: stap 5, afbeelding 1 van 2 Acer Aspire ES1-711-P1UV Screen Replacement, Screen: stap 5, afbeelding 2 van 2
    • Place the laptop on a flat surface and open it to see the screen.
    • Using your fingers or a plastic opening tool, pry open the bezel that holds the screen in place.
  6. Acer Aspire ES1-711-P1UV Screen Replacement: stap 6, afbeelding 1 van 3 Acer Aspire ES1-711-P1UV Screen Replacement: stap 6, afbeelding 2 van 3 Acer Aspire ES1-711-P1UV Screen Replacement: stap 6, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the fourteen 5mm screws around the screen.
    • Use the Phillips #0 screwdriver to remove the four 4mm screws holding in the screen.
    • Before unscrewing the screen, place a paper on the keyboard to protect the screen from scratches.
  7. Acer Aspire ES1-711-P1UV Screen Replacement: stap 7, afbeelding 1 van 2 Acer Aspire ES1-711-P1UV Screen Replacement: stap 7, afbeelding 2 van 2
    • With the screen on the paper, detach the Zero Insertion Force (ZIF) connector attaching the screen to the video cable inside of the front cover.
    • To remove the ZIF use your finger to flip up the top cover and gently pull the cable out.
    • Be sure to pry open the hinged flap not the connector socket
    • Gently remove the screen from laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Camille Ingham
418 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 829
