Inleiding
This guide provides instructions on removing the hard drive from your Acer Aspire ES1-711-p1UV laptop. You may need to follow this guide if your laptop is having troubles loading multiple pages or tabs, or is low on memory. If these issues are occuring, you may need to replace your hard drive to install new memory.
Wat je nodig hebt
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
3 andere personen hebben deze handleiding voltooid.
