Ga door naar hoofdinhoud
Acer Aspire ES1-711-P1UV Fan Replacement
Wat je nodig hebt
  1. Acer Aspire ES1-711-P1UV Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Fan Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Fan Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Fan Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Fan Replacement, Fan: stap 5, afbeelding 1 van 1
    • Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
    • Unscrew the four 5mm screws still holding down the fan.
    • The four 5mm screws in the second part of this step cannot be fully removed from the fan. Loosen them and continue on to Step 6.
  6. Acer Aspire ES1-711-P1UV Fan Replacement: stap 6, afbeelding 1 van 3 Acer Aspire ES1-711-P1UV Fan Replacement: stap 6, afbeelding 2 van 3 Acer Aspire ES1-711-P1UV Fan Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them.
    • Remove the fan assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lindsay O'Shea
414 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 630
