Ga door naar hoofdinhoud
Acer Aspire ES1-711-P1UV Battery Replacement
Wat je nodig hebt
  1. Acer Aspire ES1-711-P1UV Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Battery Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Lindsay O'Shea
414 Reputatie
3 handleidingen geschreven
2 opmerkingen
Excellent instructions, Thxz.
jmarquez_cruz - Antwoord
Wuen i reassemble my laptop doesnt power on…
mk Bane - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 25
Altijd: 4,086
