Ga door naar hoofdinhoud
Acer Aspire ES1-512-C80E Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire ES1-512-C80E Keyboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Keyboard Replacement: stap 2, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Keyboard Replacement: stap 2, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Keyboard Replacement: stap 4, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Keyboard Replacement: stap 4, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Keyboard Replacement: stap 5, afbeelding 1 van 2 Acer Aspire ES1-512-C80E Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Keyboard Replacement: stap 6, afbeelding 1 van 1
    • The keyboard is removed and ready to be replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Robert Creighton
682 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 Lid van UMass Dartmouth, Team S2-G8, Barthe Fall 2019
UMASSD-BARTHE-F19S2G8
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 1,185
