Ga door naar hoofdinhoud
Acer Aspire ES1-512-C80E Hard Drive Replacement
Wat je nodig hebt
  1. Acer Aspire ES1-512-C80E Hard Drive Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Hard Drive Replacement: stap 2, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Hard Drive Replacement: stap 2, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Hard Drive Replacement, Removing Hard Drive screws: stap 3, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Hard Drive Replacement, Removing Hard Drive screws: stap 3, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Hard Drive Replacement, Removing Hard Drive screws: stap 3, afbeelding 3 van 3
    • Using a Phillips #000 screwdriver, remove the five 1.2mm screws that hold the hard drive in place.
    • Attention Only the screw on the opposite end of the port of the hard drive needs to be removed. Then the hard drive will slide away from the Motherboard while still in the plastic case. Once slid out all the way, it lifts out separately with ease.
  4. Acer Aspire ES1-512-C80E Hard Drive Replacement: stap 4, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Hard Drive Replacement: stap 4, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Lift the hard drive, fan, motherboard, and wireless LAN card out of the device.
    • These components are still connected with wires. Remove all plugs that may be attached to other components in order to isolate the group of components.
  5. Acer Aspire ES1-512-C80E Hard Drive Replacement, Removing Drive: stap 5, afbeelding 1 van 2 Acer Aspire ES1-512-C80E Hard Drive Replacement, Removing Drive: stap 5, afbeelding 2 van 2
    • Once the four components are out of the device, the hard drive is ready to be removed.
    • To remove the hard drive, unplug it from the motherboard.
    • Attention The hard drive does not lift out of the computer CONNECTED to the motherboard. It can damage connection of hard drive on motherboard. Once the Screw on the opposite end of the port is removed, the Hard Drive should slide away from the Motherboard and lift out with ease.
Conclusie
Robert Creighton
682 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 Lid van UMass Dartmouth, Team S2-G8, Barthe Fall 2019
UMASSD-BARTHE-F19S2G8
3 Leden
7 handleidingen geschreven
Één opmerking
Not the best instructions, YouTube worked better for this laptop.
This wasn’t that difficult for me, you of course don’t need to replace the keyboard, or take out the motherboard.
After unscrewing the base and prying open the case, the keyboard side can be lifted out (Two cables need to disconnected). After unscrewing the 1 screw at the back of the HDD, I was able to slide it slowly out.
After removing the bracket from the HDD to my new SSD I slid the new drive in, screwed the bracket back down and closed up.
This should be a 4 step guide and down as moderate
Alex Culff - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 2,578
