Ga door naar hoofdinhoud
Acer Aspire ES1-512-C80E Fan Replacement
Wat je nodig hebt
  1. Acer Aspire ES1-512-C80E Fan Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Fan Replacement: stap 2, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 2, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 2, afbeelding 3 van 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: stap 3, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: stap 3, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Fan Replacement: stap 4, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 4, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 4, afbeelding 3 van 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Fan Replacement: stap 5, afbeelding 1 van 2 Acer Aspire ES1-512-C80E Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Fan Replacement: stap 6, afbeelding 1 van 1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Fan Replacement, Fan: stap 7, afbeelding 1 van 2 Acer Aspire ES1-512-C80E Fan Replacement, Fan: stap 7, afbeelding 2 van 2
    • Remove twelve 1.2mm Phillips #000 screws from the motherboard, wireless LAN card, and hard drive.
  8. Acer Aspire ES1-512-C80E Fan Replacement: stap 8, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 8, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 8, afbeelding 3 van 3
    • Using a Phillips #000 screwdriver, remove both 1.2mm screws that hold the fan in place.
  9. Acer Aspire ES1-512-C80E Fan Replacement: stap 9, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 9, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 9, afbeelding 3 van 3
    • Lift the fan, hard drive, motherboard, and wireless LAN card out of the device.
    • These components are still connected with wires. Remove all plugs that may be attached to other components in order to isolate the group of components.
  10. Acer Aspire ES1-512-C80E Fan Replacement: stap 10, afbeelding 1 van 1
    • Flip over the motherboard.
    • Remove all three 1.2mm Phillips #00 screws that attach the fan to the motherboard.
  11. Acer Aspire ES1-512-C80E Fan Replacement: stap 11, afbeelding 1 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 11, afbeelding 2 van 3 Acer Aspire ES1-512-C80E Fan Replacement: stap 11, afbeelding 3 van 3
    • The fan and motherboard are still connected with wires. Remove any plugs that may be attaching the components
    • Remove the fan from the motherboard.
Conclusie
Robert Creighton
682 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 Lid van UMass Dartmouth, Team S2-G8, Barthe Fall 2019
UMASSD-BARTHE-F19S2G8
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 397
