Inleiding
If your Acer Aspire E5-571P-55TL is running slowly, programs are crashing, or fails to start, you may need to replace the (or install additional) memory or RAM. The memory contains the local data and information for every active process on your laptop. To see common issues which may require RAM replacement, see our Acer E5-571P-55TL troubleshooting guide.
This guide will explain how to replace the RAM for the Acer E5-571P-55TL. Before performing actions in this guide be sure to power off your laptop and remove the power adapter.
Wat je nodig hebt
Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
Carefully place your fingers underneath the top of the keyboard just below the screen.
Pull upwards until you can hear the keyboard click out of place.
Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
With a Phillips #0 screwdriver, remove the two 4 mm screws from the motherboard.
Flipe the motherboard over.
Using the tips of each index finger, gently pull the clips away from the RAM module.
