Ga door naar hoofdinhoud
Acer Aspire E5-571P-55TL RAM Replacement
Wat je nodig hebt
  1. Acer Aspire E5-571P-55TL RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL RAM Replacement: stap 2, afbeelding 1 van 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL RAM Replacement: stap 3, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement: stap 3, afbeelding 2 van 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL RAM Replacement, Keyboard: stap 4, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL RAM Replacement: stap 5, afbeelding 1 van 3 Acer Aspire E5-571P-55TL RAM Replacement: stap 5, afbeelding 2 van 3 Acer Aspire E5-571P-55TL RAM Replacement: stap 5, afbeelding 3 van 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL RAM Replacement, CPU Fan: stap 6, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement, CPU Fan: stap 6, afbeelding 2 van 2
    • Before replacing the CPU fan, you'll have to remove the network card found below the fan.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
    • Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
  7. Acer Aspire E5-571P-55TL RAM Replacement: stap 7, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement: stap 7, afbeelding 2 van 2
    • The CPU fan can be found in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws from the fan.
  8. Acer Aspire E5-571P-55TL RAM Replacement: stap 8, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement: stap 8, afbeelding 2 van 2
    • Use tweezers to safely remove the fan plug from the motherboard. To remove the plug, gently push left.
  9. Acer Aspire E5-571P-55TL RAM Replacement: stap 9, afbeelding 1 van 1
    • Make sure that all fan wires are disconnected from the board.
    • Lift the curved end of the fan, and safely remove it.
  10. Acer Aspire E5-571P-55TL RAM Replacement, Hard Drive: stap 10, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  11. Acer Aspire E5-571P-55TL RAM Replacement: stap 11, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement: stap 11, afbeelding 2 van 2
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  12. Acer Aspire E5-571P-55TL RAM Replacement: stap 12, afbeelding 1 van 1
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
  13. Acer Aspire E5-571P-55TL RAM Replacement, Motherboard: stap 13, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement, Motherboard: stap 13, afbeelding 2 van 2
    • With a Phillips #0 screwdriver, remove the two 4 mm screws from the motherboard.
  14. Acer Aspire E5-571P-55TL RAM Replacement: stap 14, afbeelding 1 van 3 Acer Aspire E5-571P-55TL RAM Replacement: stap 14, afbeelding 2 van 3 Acer Aspire E5-571P-55TL RAM Replacement: stap 14, afbeelding 3 van 3
    • Carefully disconnect the speaker connection to the motherboard.
  15. Acer Aspire E5-571P-55TL RAM Replacement: stap 15, afbeelding 1 van 3 Acer Aspire E5-571P-55TL RAM Replacement: stap 15, afbeelding 2 van 3 Acer Aspire E5-571P-55TL RAM Replacement: stap 15, afbeelding 3 van 3
    • The last connection to the motherboard is the screen. Gently disconnect the cable from the motherboard.
  16. Acer Aspire E5-571P-55TL RAM Replacement: stap 16, afbeelding 1 van 1
    • Lift the motherboard up from the top right corner, and then pull it right to release it from the case.
  17. Acer Aspire E5-571P-55TL RAM Replacement, RAM: stap 17, afbeelding 1 van 2 Acer Aspire E5-571P-55TL RAM Replacement, RAM: stap 17, afbeelding 2 van 2
    • Flipe the motherboard over.
    • The RAM is locked into place by two clips.
    • Using the tips of each index finger, gently pull the clips away from the RAM module.
  18. Acer Aspire E5-571P-55TL RAM Replacement: stap 18, afbeelding 1 van 1
    • When the RAM stick is released, slide it out of the slot.
Conclusie
Max Piekos
459 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team B-1, Gurgel Spring 2022 Lid van UMass Dartmouth, Team B-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SBG1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 362
