Ga door naar hoofdinhoud
Acer Aspire E5-571P-55TL Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire E5-571P-55TL Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Keyboard Replacement: stap 3, afbeelding 1 van 2 Acer Aspire E5-571P-55TL Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Acer Aspire E5-571P-55TL Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Keyboard Replacement: stap 5, afbeelding 1 van 3 Acer Aspire E5-571P-55TL Keyboard Replacement: stap 5, afbeelding 2 van 3 Acer Aspire E5-571P-55TL Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
Conclusie
Melvin Baptista
135 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team B-1, Gurgel Spring 2022 Lid van UMass Dartmouth, Team B-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SBG1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 152
