Inleiding
If your Acer Aspire E5-571P-55TL is taking excessively long periods of time to open or run programs, your hard drive may need to be replaced. The hard drive is a physical disk that is constantly read from and written on, which leads to wear-and-tear over time. To see more common issues which may require hard drive removal, see our Acer E5-571P-55TL troubleshooting guide.
This guide will explain how to replace the hard drive for the Acer E5-571P-55TL. Before performing actions in this guide be sure to power off your laptop and remove the power adapter.
Wat je nodig hebt
Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
Carefully place your fingers underneath the top of the keyboard just below the screen.
Pull upwards until you can hear the keyboard click out of place.
Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
