Ga door naar hoofdinhoud
Acer Aspire E5-571 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Keyboard Replacement: stap 5, afbeelding 1 van 3 Acer Aspire E5-571 Keyboard Replacement: stap 5, afbeelding 2 van 3 Acer Aspire E5-571 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 Keyboard Replacement: stap 6, afbeelding 1 van 2 Acer Aspire E5-571 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
Conclusie
9 andere personen hebben deze handleiding voltooid.
daniel sawyer
2.566 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-2, Meier Fall 2015 Lid van USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Leden
4 opmerkingen
keyboard cable is a b$%*h
shrs - Antwoord
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - Antwoord
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - Antwoord
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 12,197
