Ga door naar hoofdinhoud
Acer Aspire E5-571 Battery Replacement
Wat je nodig hebt
  1. Acer Aspire E5-571 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Battery Replacement: stap 2, afbeelding 1 van 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Battery Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery towards you to remove it from the laptop.
Conclusie
6 andere personen hebben deze handleiding voltooid.
daniel sawyer
2.566 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-2, Meier Fall 2015 Lid van USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Leden
2 opmerkingen
Uh…this makes no mention of the keyboard. Why is this titled as a keyboard repair, when it simply removes the battery?
David Greene - Antwoord
lets hope next time the “This guide is being worked on by hardworking students. “ the steps involve more then just removing the battery
mechanimal15 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 74
Altijd: 23,594
