Ga door naar hoofdinhoud
Acer Aspire E3-111-C0WA Wireless Card Replacement
Wat je nodig hebt
  1. Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 2, afbeelding 1 van 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 2, afbeelding 2 van 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 2, afbeelding 3 van 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 3, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 4, afbeelding 1 van 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 4, afbeelding 2 van 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 4, afbeelding 3 van 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 5, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 6, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: stap 7, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: stap 7, afbeelding 2 van 2
    • Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
  8. Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 8, afbeelding 1 van 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 8, afbeelding 2 van 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: stap 8, afbeelding 3 van 3
    • Remove the 6.2mm #1 Phillips head screw attaching the wireless card to the case.
    • Pull the wireless card horizontally away from the motherboard to remove it from the connector.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jonathan Chandler
503 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 322
