Ga door naar hoofdinhoud
Acer Aspire E3-111-C0WA Touchpad Replacement
Wat je nodig hebt
  1. Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 2, afbeelding 1 van 3 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 2, afbeelding 2 van 3 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 2, afbeelding 3 van 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 3, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 4, afbeelding 1 van 3 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 4, afbeelding 2 van 3 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 4, afbeelding 3 van 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 5, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 6, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 6, afbeelding 2 van 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: stap 7, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: stap 7, afbeelding 2 van 2
    • Lift up on the black tab to release the ribbon cable from the touchpad.
    • Lightly pull on the blue tab to remove the cable from the connector.
  8. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 8, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 8, afbeelding 2 van 2
    • Peel up the silver tape adhering the touchpad cable to the case, revealing two screws underneath.
  9. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 9, afbeelding 1 van 2 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 9, afbeelding 2 van 2
    • Unscrew the three 6.2mm Phillips #1 screws holding the touchpad to the case.
  10. Acer Aspire E3-111-C0WA Touchpad Replacement: stap 10, afbeelding 1 van 3 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 10, afbeelding 2 van 3 Acer Aspire E3-111-C0WA Touchpad Replacement: stap 10, afbeelding 3 van 3
    • Lift the touchpad assembly out of the case by its corners.
    • Slide the touchpad out of the chassis from under the speaker cable, taking care not to damage the cable.
    • Check to make sure the small strip of conductive tape connecting the copper pad on the PCB to the metal assembly is properly adhered.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jonathan Chandler
503 Reputatie
4 handleidingen geschreven
Één opmerking
Well made instruction, presumably works on all E3-111 devices; it did on my E3-111-C45G.
The spare parts number (Europe) is Acer No. TAA4329129, dubbed “Original Acer Touchpad / Touchboard silver Aspire E3-11 series”. Should cost around 22-25€.
ce re - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 959
