Inleiding
If you feel your Acer Aspire E1-572-6829 overheating or notice the battery draining quickly, follow this guide to replace the battery. This guide will demonstrate how to remove as well as reinsert the battery, a process required for replacing this component as well as numerous others.
The battery is an important component to your laptop that provides its power. A dying battery can become hot, causing your laptop to overheat. This can damage other important components of the device, so a battery replacement may be necessary. Additionally, your device's battery may drain more quickly over time. If calibrating the battery, as described in our troubleshooting page, doesn't solve the issue, it may need to be replaced.
Make sure that your device is powered off and the charger is unplugged before beginning the steps in this guide.
Wat je nodig hebt
Flip the laptop over so that you are facing the back panel.
Locate the battery lock switch below the battery.
Één andere persoon heeft deze handleiding voltooid.
