Inleiding
If your system overheating you must to clean the Heatsink system and/or change the thermal paste compound.
You must be very careful when you working with the motherboard. There are small components that can easily pulled down.
Please SUBSCRIBE to my channel ツ
Video overzicht
  1. Switch-off the laptop. Remove the battery and the DVD drive. Remove the battery and the DVD drive.
    • Switch-off the laptop.
    • Remove the battery and the DVD drive.
  2. Unscrew 2x screws M 2.5x8.0 With a plastic tool remove the Memory RAM / Hard Drive / Wifi Cover Door With a plastic tool remove the Memory RAM / Hard Drive / Wifi Cover Door
    • Unscrew 2x screws M 2.5x8.0
    • With a plastic tool remove the Memory RAM / Hard Drive / Wifi Cover Door
  3. Remove the SATA HDD, RAM meory module and WiFi mini PCI card More detailed information for this step you can found in this manual:   Acer Aspire E1-571 - HDD / RAM Memory / WiFi card Replacement .
  4. The Keyboard is held by 6x locking clips at up and 2x at both sides. Use plastic tool to unlock 6x upper clips. Disconnect the keyboard flex cable and you are ready to install the new keyboard.
    • The Keyboard is held by 6x locking clips at up and 2x at both sides.
    • Use plastic tool to unlock 6x upper clips.
    • Disconnect the keyboard flex cable and you are ready to install the new keyboard.
    • More detailed information for this step you can found in this manual: Acer Aspire E1-571 - Keyboard Replacement
  5. Now is time for screws :) 16x M3.0x8.0 2x M2.5x5.0
    • Now is time for screws :)
    • 16x M3.0x8.0
    • 2x M2.5x5.0
    • 3x M2.0x3.0
  6. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  7. Power switch cable connector Mouse cable connector Use plastic tool to separate the upper case.
    • Power switch cable connector
    • Mouse cable connector
    • Use plastic tool to separate the upper case.
  8. Remove the 2x screws and disconnect 5x flex cable connectors: 2x Loudspeakers cable connectors LCD Display cable connector
    • Remove the 2x screws and disconnect 5x flex cable connectors:
      • 2x Loudspeakers cable connectors
      • LCD Display cable connector
      • Microphone cable connector
      • USB board flex cable connector
    • Don't forget to remove the Card Reader Blanking Plate.
    • To take out the Motherboard, pick-up it first from the right side (near to the DVD drive connector).
  9. Disconnect the Power /Charging cable connector from the back side of the Motherboard. Disconnect the Power /Charging cable connector from the back side of the Motherboard.
    • Disconnect the Power /Charging cable connector from the back side of the Motherboard.
  10. 3x screws hold the fan to the Motherboard. Another 4x screws and you can open and clean the fan from inside. Another 4x screws and you can open and clean the fan from inside.
    • 3x screws hold the fan to the Motherboard.
    • Another 4x screws and you can open and clean the fan from inside.
  11. Clean the radiator by using soft brush. Clean the radiator by using soft brush.
    • Clean the radiator by using soft brush.
  12. Remove the heat sink system. Careful remove the old thermal patse from the Processor and from the Head-sync system. Careful remove the old thermal patse from the Processor and from the Head-sync system.
    • Remove the heat sink system.
    • Careful remove the old thermal patse from the Processor and from the Head-sync system.
  13. Put a new thermal paste. Cover the entire surface of the CPU crystal. Install the Heat-sync system and screw the screws at a few steps. Install the Heat-sync system and screw the screws at a few steps.
    • Put a new thermal paste. Cover the entire surface of the CPU crystal.
    • Install the Heat-sync system and screw the screws at a few steps.
  14. Assemble the laptop and after switch-on it check is the fan working.
    • Assemble the laptop and after switch-on it check is the fan working.
Conclusie
6 andere personen hebben deze handleiding voltooid.
ZFix
162.332 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
783 handleidingen geschreven
Sir acer e1 571 me cpu kon sa hota hy matlb uska no kya hota hy core i5 kaa hmko confrm karna hy kyu ki maine apna lapie dukan pe diya tha aur mujhe dr hy ki wo nera cpu to nhi change kardiya
chaudharypiyush496 - Antwoord
This video was a lifesaver. It helped me take apart My E1 in order to replace the thermalpaste and cleanup he cooling. Big Thanks!
Chris Smith - Antwoord
Thank You, this worked great on an Acer V3-571, totally removed cooling/fan issues, Thank You.
Shane Archer - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 5
Afgelopen 7 Dagen: 25
Afgelopen 30 Dagen: 122
Altijd: 13,135
