Ga door naar hoofdinhoud
Acer Aspire E1-531-2438 RAM Replacement
Wat je nodig hebt
  1. Acer Aspire E1-531-2438 RAM Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire E1-531-2438 RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 RAM Replacement: stap 2, afbeelding 1 van 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 RAM Replacement, RAM: stap 3, afbeelding 1 van 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: stap 3, afbeelding 2 van 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: stap 3, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  4. Acer Aspire E1-531-2438 RAM Replacement: stap 4, afbeelding 1 van 3 Acer Aspire E1-531-2438 RAM Replacement: stap 4, afbeelding 2 van 3 Acer Aspire E1-531-2438 RAM Replacement: stap 4, afbeelding 3 van 3
    • Gently press outward on the two tabs that lock the RAM module in place.
    • Once the RAM module releases and flips up, gently pull the RAM module directly out of its socket.
Conclusie
Jakob Rinkus
965 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 Lid van UMass Dartmouth, Team S8-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S8G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 587
