Ga door naar hoofdinhoud
Acer Aspire E1-531-2438 Battery Replacement
Wat je nodig hebt
  1. Acer Aspire E1-531-2438 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire E1-531-2438 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Battery Replacement: stap 2, afbeelding 1 van 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jakob Rinkus
965 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 Lid van UMass Dartmouth, Team S8-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S8G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 1,380
