Ga door naar hoofdinhoud
Acer Aspire E1-510P-4637 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire E1-510P-4637 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Keyboard Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 6, afbeelding 1 van 2 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 7, afbeelding 1 van 3 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 7, afbeelding 2 van 3 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 Keyboard Replacement, Keyboard: stap 8, afbeelding 1 van 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 11, afbeelding 1 van 3 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 11, afbeelding 2 van 3 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 11, afbeelding 3 van 3
    • Rotate the back cover up a little to reveal the cables connected to the motherboard.
    • Unplug the cables by sliding them out of their receptacle.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
    • Remove the two M2x3 screws with a PH0 Phillips screwdriver.
  13. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 13, afbeelding 1 van 3 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 13, afbeelding 2 van 3 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 13, afbeelding 3 van 3
    • Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
  14. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 14, afbeelding 1 van 2 Acer Aspire E1-510P-4637 Keyboard Replacement: stap 14, afbeelding 2 van 2
    • Peel off the foil adhesive stuck to the keyboard.
  15. Acer Aspire E1-510P-4637 Keyboard Replacement: stap 15, afbeelding 1 van 1
    • Remove the keyboard.
Conclusie
Caleb lindsay
778 Reputatie
6 handleidingen geschreven
Cal Poly, Team 34-15, Maness Spring 2016 Lid van Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,179
