Ga door naar hoofdinhoud
Acer Aspire E1-510-2500 RAM Card Replacement
Wat je nodig hebt
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: stap 2, afbeelding 1 van 2 Acer Aspire E1-510-2500 RAM Card Replacement: stap 2, afbeelding 2 van 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: stap 3, afbeelding 1 van 2 Acer Aspire E1-510-2500 RAM Card Replacement: stap 3, afbeelding 2 van 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: stap 4, afbeelding 1 van 2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: stap 4, afbeelding 2 van 2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: stap 5, afbeelding 1 van 2 Acer Aspire E1-510-2500 RAM Card Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: stap 6, afbeelding 1 van 3 Acer Aspire E1-510-2500 RAM Card Replacement: stap 6, afbeelding 2 van 3 Acer Aspire E1-510-2500 RAM Card Replacement: stap 6, afbeelding 3 van 3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: stap 7, afbeelding 1 van 2 Acer Aspire E1-510-2500 RAM Card Replacement: stap 7, afbeelding 2 van 2
    • Carefully remove the RAM card from its home.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sebastian Taylor
733 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G5, Julie Fall 2017 Lid van UMass Dartmouth, Team S2-G5, Julie Fall 2017
UMASSD-JULIE-F17S2G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 564
