Ga door naar hoofdinhoud
Acer Aspire E1-510-2500 Fan Replacement
Wat je nodig hebt
  1. Acer Aspire E1-510-2500 Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 Fan Replacement: stap 2, afbeelding 1 van 2 Acer Aspire E1-510-2500 Fan Replacement: stap 2, afbeelding 2 van 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 Fan Replacement: stap 3, afbeelding 1 van 2 Acer Aspire E1-510-2500 Fan Replacement: stap 3, afbeelding 2 van 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 Fan Replacement, Motherboard: stap 4, afbeelding 1 van 3 Acer Aspire E1-510-2500 Fan Replacement, Motherboard: stap 4, afbeelding 2 van 3 Acer Aspire E1-510-2500 Fan Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Using a Phillips 1 screwdriver, remove the 17 9 mm screws from the bottom of the laptop, including the one in the back panel.
    • Using a plastic opening tool, carefully remove the back panel.
    • Remove the 9mm screw under the back panel.
    • When reassembling, insert the back panel from the bottom edge first.
  5. Acer Aspire E1-510-2500 Fan Replacement: stap 5, afbeelding 1 van 1
    • Using a plastic opening tool, carefully separate the frame along the edges of the laptop. This should separate the keyboard assembly from the bottom portion of the laptop.
  6. Acer Aspire E1-510-2500 Fan Replacement: stap 6, afbeelding 1 van 3 Acer Aspire E1-510-2500 Fan Replacement: stap 6, afbeelding 2 van 3 Acer Aspire E1-510-2500 Fan Replacement: stap 6, afbeelding 3 van 3
    • Open the laptop, leaving the screen flat on the table.
    • Carefully pull the keyboard assembly out away from the base of the laptop. There should be three connections visible in the gap between the keyboard assembly and the base.
    • Using tweezers, carefully detach the connections from the base.
    • Place the keyboard assembly and the disk tray place holder aside.
    • For reassembly, leave the disk tray place holder out until after the blue tape connector has been reconnected, to have enough space to reattach the tape. The disk tray place holder can then be slid back into place from the side of the laptop.
  7. Acer Aspire E1-510-2500 Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the six wire connections to the motherboard.
    • Remove the tape connection by lifting the plastic black holding piece and carefully pulling the tape out of it's slot.
  8. Acer Aspire E1-510-2500 Fan Replacement: stap 8, afbeelding 1 van 2 Acer Aspire E1-510-2500 Fan Replacement: stap 8, afbeelding 2 van 2
    • Using a Phillips 1 screwdriver, remove the two 5mm screws from the motherboard.
    • Using a Phillips 1 screwdriver, remove the black 5mm screw from the fan.
    • Using a Phillips 1 screwdriver, remove the black 3mm screw from the WiFi card.
  9. Acer Aspire E1-510-2500 Fan Replacement: stap 9, afbeelding 1 van 1
    • Carefully remove the motherboard by lifting along the right edge first.
    • The headphone jack and the connection to the battery are both attached to the motherboard and under part of the casing. Pulling roughly at the motherboard could damage either or both of these pieces.
  10. Acer Aspire E1-510-2500 Fan Replacement, Fan: stap 10, afbeelding 1 van 1
    • Detach the connector between the fan and the motherboard.
  11. Acer Aspire E1-510-2500 Fan Replacement: stap 11, afbeelding 1 van 3 Acer Aspire E1-510-2500 Fan Replacement: stap 11, afbeelding 2 van 3 Acer Aspire E1-510-2500 Fan Replacement: stap 11, afbeelding 3 van 3
    • Flip the motherboard over so that the back is face-up.
    • Unscrew the three 5mm screws and lift the fan off of the motherboard.
Conclusie
Sebastian Taylor
733 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G5, Julie Fall 2017 Lid van UMass Dartmouth, Team S2-G5, Julie Fall 2017
UMASSD-JULIE-F17S2G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 430
