Ga door naar hoofdinhoud
Acer Aspire E1-470P-6659 Motherboard Replacement
Wat je nodig hebt
  1. Acer Aspire E1-470P-6659 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 3, afbeelding 1 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 3, afbeelding 2 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 4, afbeelding 1 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 4, afbeelding 2 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: stap 5, afbeelding 1 van 2 Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: stap 5, afbeelding 2 van 2
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 6, afbeelding 1 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 6, afbeelding 2 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: stap 11, afbeelding 2 van 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: stap 11, afbeelding 3 van 3
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Motherboard Replacement: stap 12, afbeelding 1 van 2 Acer Aspire E1-470P-6659 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
Conclusie
Faith Lobaton
497 Reputatie
3 handleidingen geschreven
UC Davis, Team S4-G5, Lore Fall 2018 Lid van UC Davis, Team S4-G5, Lore Fall 2018
UCD-LORE-F18S4G5
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 878
